rocker arm question
rocker arm question
i have been offered a set or rocker arms with a 1.6 ratio for free from a friend and was wondering if there would be any actual gainsfrom running these instead of the stockers.
RE: rocker arm question
Should work pretty good, but you have to make sure that the rockers are compatible as well as good enough (ie not worn or damaged) to install.
well these are offa roller 350 and they only have maybe a 100 miles on them so they should be good
monette999
04-12-2014 12:41 AM
Cobra102000
02-03-2011 02:55 PM
ericthughes
10-19-2010 03:13 PM
