rocker cover sensor??
I don't know how to describe this problem i have but i will give it my best shot.
On the passenger sideof my enginethere is abrittle plasticpipe connected to what i can only describe as some sort of sensor which pushes into a hole on the head/rocker cover the other end of the pipe is connected to anozzle which situated on top of the plenham near the throttle cable
hope your still with me ??
Well my question is does this sensor thing which is pushed into the head/rocker cover just push in or does it lock in by some way as mine keeps on coming out of the hole and tripping my service engine soon light; as soon as i push it back in the hole everything is normal again and the light goes out.
There is also another sensor fitted into the drivers side head/rocker cover but that seems to be in tight and gives me no trouble
my car is a 1994 s 10 blzer with the vortec 4.3 engine fitted
thanks in advance
Keith UK
thanks in advance
Keith UK
I think the sensor on the drivers side is going to be your Positive Crankcase Ventilation (PCV) valve. At least it is in the gen 2 blazers. This sensor just gets pushed in till you can't push no more, very easy to replace. The other one I am not sure what it is.
zombiewoof
Feb 17, 2008 07:03 AM
