rotor
Old Feb 26, 2009 | 05:37 PM
banshee386's Avatar
banshee386 is an unknown quantity at this point
Default rotor
Im having trouble installing my rotor back into my engine it's a 1995 blazer Vin w i marked it with paint before i took it out and now when i go to drop it in how it was it will only drop in way ahead of my marks i tried wiggling it and shakeing it any idea's ?
Old Feb 26, 2009 | 07:50 PM
Default RE: rotor
Sounds like you are one tooth off with the distributor. The oil pump drive shaft is likely hanging you up because it is not in the proper position. It is going to be fun...
Old Feb 26, 2009 | 10:06 PM
banshee386's Avatar
Default RE: rotor
yea thats what i was thinking is there a way to move the oil pump drive to line it up better so it'll fix in there its to far back to be able to look down into the hole so i cant see any thing
Old Feb 27, 2009 | 06:49 AM
Default RE: rotor
Get a mirror and a long, slender screw driver. You need good lighting as well.
Old Mar 1, 2009 | 03:23 PM
rowe's Avatar
rowe is an unknown quantity at this point
Default RE: rotor
wow,,,im glad i looked at this post.
doesnt sound to good when ur having problems
just putting a rotor in.
no pun intended.
Old Mar 1, 2009 | 04:36 PM
Default RE: rotor
If you were just changing the rotor, this would not happen. But I believe the OP stated rotor when actually speaking of the distributor.
urbex
Jan 10, 2010 10:47 PM
KLBlazer07
Jan 28, 2007 06:00 PM
Marcin
Nov 24, 2006 12:38 AM
Blasir
Oct 1, 2006 11:05 PM
kornphlake
Aug 11, 2006 05:55 AM
