Rough Idle P0300
Old Nov 6, 2015 | 12:23 PM
LesMyer's Avatar
Originally Posted by kingofpoland
roger, ill have the ducks lined up for tomorrow. expect update later on tomorrow
Sounds like a plan! Until then. FWIW, I see in your distributor photo that the rotor is indeed lined up with the stamped 6 and that it has the factory hold down - so as long as the balancer mark was lined up right on TDC#1 - this distributor was installed correctly. Rotor terminals look pretty sad so it seems spark may have been jumping around due to cmp retard being off. Common cause of this is a worn distributor gear or bushings. We can check that out next. In the meantime I would go ahead and replace the cap/rotor - they seem to need it. Please still do the other tests indicated first.
reevesjo
Sep 22, 2015 05:43 PM
CabraMonster
Oct 24, 2011 05:51 PM
bkw
18
Jun 6, 2011 09:07 AM
bjd15
Feb 13, 2010 09:49 AM
vaportrail
Aug 16, 2009 06:15 PM
