RPM question
Old Apr 27, 2010 | 01:06 PM
A/M/G's Avatar
A/M/G is on a distinguished road
not trying to hijack a thread, what turns the fuel off at 5600 rpm, my truck is doing this intermittently. it will just go to idle, the same thing happens when at high rpms. it drops to idle and will not accel. resets when the key is turned off and restarted.
Old Apr 27, 2010 | 01:17 PM
The only fuel cutoff there is occurs at the speed limiter. And nothing should knock it back to idle until the key is cycled.
Old Apr 27, 2010 | 02:00 PM
A/M/G's Avatar
Ok speed limiter, my vehicle drops to idle and will not accel until the key is cycled. i know it is a fuel issue. I have a fuel gage in front of the windshield. It drives fine until the fuel pressure drops to 50 psi after releasing the gas pedal and starting to re-accel. The pressure drops to 50 and upon increased throttle pressure drops to 40 psi, bucking-jumping-popping, press to floor it dies. Cycle the key 62 psi, it runs again , starts idles 54-55 psi, accel 58-59 psi, when falls to 50 psi faults again.
Speed limiter, is it a physical switch or part of the computer program?
Could the crank sensor cause this problem.
I have been fighting this for 3 MONTHS.
I have read hours on this forum, tried LOTS of stuff including your fuel diagnosis chart in the DIY section. I am at my witts end.
Old Apr 27, 2010 | 02:05 PM
Well, considering that you have another thread on this topic, lets not drive this one further off its original topic to discuss your vehicular issues. Repost this in your thread.
altoncustomtech
Performance & Brainstorming
Oct 20, 2014 08:33 AM
newguy
Sep 29, 2014 06:12 PM
Mgern26
Jun 17, 2012 03:33 PM
dimmuborgir6nik6
Oct 10, 2008 10:34 AM
Private_Ops
Jan 30, 2008 11:44 AM
