Running Hot
Old Jan 24, 2008 | 12:07 PM
seattleres's Avatar
seattleres is an unknown quantity at this point
Default Running Hot
What is the average temp of the blazer, is it 210? After driving for a while my car goes to 220 to 225 and can drop back to 210.
I never get the overheat light but just curious what could be going on. My coolant is full in the engine coolant reserve.
Old Jan 24, 2008 | 12:48 PM
HeyYou's Avatar
HeyYou is an unknown quantity at this point
Default RE: Running Hot
The thermostat is supposed to open at 195. Don't expect the in-dash gauge to be perfectly accurate..... 200 is prolly about right.
Old Jan 24, 2008 | 06:59 PM
thegr81's Avatar
What does your coolant look like??? Does it look dirty at all?? I would do a cooling system flush and replace the thermostat if I was running hot!!!
Old Feb 6, 2008 | 12:50 AM
Chevy Lover's Avatar
What year is your blazer?
Old Feb 7, 2008 | 02:57 PM
WisdomRacing's Avatar
WisdomRacing is an unknown quantity at this point
If the temperature starts to climb then abruptly lowers, that would indicate you are low on coolant..the rise would be caused by an air bubble in the system and the fall is when coolant gets to the sensor. Check your coolant levels (and cap while you're at it) and if that isn't the problem, a thermostat sounds right.
stevenhousden
Jul 6, 2014 05:56 PM
Mandrwj
Apr 10, 2011 07:32 PM
88_s10
Jan 15, 2011 05:04 PM
ravenhurst
15
Apr 26, 2009 07:53 AM
BlaZinNaTe
Engine & Internal
Jan 14, 2006 10:50 PM
