Running Problems
94 s10 blazer, multiport,,,
new iac because is gave theengine code of 35and fuel pressure regulator because i smelled excessivefuel,no carbon in egr, no dummy codes being seen since the iac replacement but no change.
blazer will start to miss at first but later, it gets so bad to point while it is in park, I can rev up the engine and will act justlike it hasa rev limiter , it won't run for crap down the road for surging and threatening to cut completely off. the other night it quit in the garage and would not even start back........pulled a plug to see if it had fire and it did and there was fuel pressure...ruling out the pump.
any ideas
any ideas
ksimpson
14
Oct 7, 2013 05:25 AM
upblazer95
Apr 4, 2009 08:27 PM
Ballysto
18
Dec 23, 2008 10:15 PM
89BlazerGuy
Dec 10, 2006 12:13 PM
