Running very sluggish and rich
Old Nov 4, 2013 | 10:35 PM
Black Sheep's Avatar
Black Sheep is on a distinguished road
Default Running very sluggish and rich
Hey guys. I am having problems with my 86 Blazer. I have the 350 small block with a edlebrock proformer 650 cfm. I recently brought this truck and it had head gasket problems. So i have changed the head gasket, plugs and leads, she now starts and runs. The problem is she is running rich blowing white smoke from the exhaust and really sluggish, and lags and stalls out if i accelerate too hard.
I have followed the engine timing correctly and set the timimg to 10deg before tdc. I have tried the basic idle mixture screws on the front of the carb but nothing seems to work.
If any one can help or give me a few pointers that would be great.
Old Nov 5, 2013 | 03:21 AM
Chevy33's Avatar
Chevy33 is on a distinguished road
Default Running rich with white smoke
White smoke usually indicates water being burned. Do you have coolant in? If you do and the exhaust smells sweet then I would look to the intake gasket or the head gasket. A rich condition would cause a heavy unburned fuel smell at the exhaust. With no computer controlling the fuel then no over compensation is occurring.
Old Nov 5, 2013 | 03:33 AM
chris015's Avatar
sounds like somewhere in installation something went wrong.
new head bolts? everything torqued to spec in right order? (cant cheap out here)
edit : this guy below me is right too
Old Nov 5, 2013 | 03:37 AM
Chevy33's Avatar
I forgot to ask if you had the heads checked. If you ever take them off you should have them checked for cracks.
Old Nov 5, 2013 | 07:39 AM
Yes i had the heads and block checked. The compression is good across all cylinders. Im not getting the sweet smell with the smoke you usualy get when coolant is burnt. It is definatly overfueling and running rich as you can smell it and the exhaust gasses make my eyes run.
I replaced all gaskets, bolts and torqued them correctly i ensures all debris was removed and cleaned..
Old Nov 5, 2013 | 07:49 AM
chris015's Avatar
id say its that edlebrock carb giving you a fit. I dont like them. How many turns out are the fuel screws?
Old Nov 5, 2013 | 01:07 PM
Hey Chris. They are out 3 turns both. I followed the reccomendations - in all the way till it sputters then out till it sputters and backbit off to the appx mid point. Tried this on each of the screws a couple of times. Hasnt seemed to make any difference.
I think it could be the carb as i have just screwed them both fully in and the engine didnt stall at all.
Old Nov 5, 2013 | 01:53 PM
chris015's Avatar
Ah,it is indeed the carb then. Im a fan of holley,and quad. the quads are a fit to tune,but if tuned correctly they can be the best carbs for street.
ksimpson
14
Oct 7, 2013 05:25 AM
THePaRaSiTE5771
May 22, 2012 10:08 PM
klote82
Apr 27, 2012 08:22 PM
badbowtie359
Sep 9, 2011 10:12 AM
dlangley
Jan 8, 2010 10:31 AM
