runs poorly when cold
Old Apr 7, 2014 | 11:09 AM
6 gun's Avatar
6 gun is on a distinguished road
Default runs poorly when cold
When first starting the engine it's a little slow to fire up maybe 3-4 seconds then if you try to take off it bake fires through the intake. Once it gets up to about 125- 150 it starts to run a lot better. After that it has a slight hesitation and seems like it doesn't have good power once rpms build up it has good power. I put new plugs,wires,rotor,cap temp sensor, I took a fuel pressure reading at the fuel filter it read 15 psi checked vacuum line and fixed anything that looked dry rotted and such. I got this truck in a trade and the guy who had it before me made a mess.It has headers there's wires not plugged in to anything air pump missing and I don't know what else is missing. One more thing when timing is set on 2 with ecm unplugged my timing mark is way to the left not even in degree indicator marks like it's to far advanced.I know timing is suppose to be on 0 but I didn't think 2 degree's would make a lot of difference. Any suggestions please
LesMyer
Jul 15, 2015 10:06 AM
English Rose
Jan 8, 2013 01:47 PM
fox3r
Feb 10, 2011 10:29 PM
zakm0n
Jan 10, 2011 11:42 AM
AirJer
Feb 11, 2010 01:44 PM
