S15 push button only goes into 4x4 in neutral
Old Feb 1, 2014 | 07:13 PM
S15JIMMY's Avatar
S15JIMMY is on a distinguished road
Question S15 push button only goes into 4x4 in neutral
I bought this vehicle a couple month back and 4x4 worked as supposed to according to owner manual. Now without warning 4Hi only goes in if stopped and in neutral just like if you would if you'd shift into 4lo. Once in 4Hi ,the indicator lamps aren't lit, even tho it's fully engaged. The indicator lamps work when they self check when you first turn ign. on. In addition 4lo has only 1st gear now instead of 3. Anybody ever had this happen? I should prob mention this is a shift on the fly 4x4 where you can shift into 4Hi at "any" speed according to the manual.
Last edited by S15JIMMY; Feb 1, 2014 at 07:17 PM. Reason: forgot to mention the shift on the fly thing
91chevywt
Feb 21, 2011 07:12 PM
trapper_canada
16
Jan 1, 2010 11:04 AM
Rottidog
Dec 3, 2009 10:47 AM
buggyblazer
14
Dec 23, 2008 08:22 PM
upblazer95
Nov 15, 2008 06:55 PM
