seafoam 00 4.3
Old Nov 3, 2012 | 05:20 PM
4x4on20s's Avatar
4x4on20s is on a distinguished road
Default seafoam 00 4.3
i just seafoamed my 00 4.3 and if anybody has heard of this you know whats suppose to do.. problem here is that mine didnt smoke like it should have. after i poured it into the vacuum line i noticed a wet spot behind my tail pipe. run it down the road and back and nothing happened..
Old Nov 3, 2012 | 06:32 PM
richphotos's Avatar
did you follow the directions properly, once you are almost there with pouring all you need in the vac line (brake booster vac line btw) you pour enough in there to kill the engine
Old Nov 3, 2012 | 06:41 PM
4x4on20s's Avatar
ive done it before. i looked up on youtube on what hose to pour it in first to be sure. my wife metioned a vacuum leak but wouldnt i see the smoke come from a hose under the hood?
Old Nov 3, 2012 | 06:59 PM
1sttimejimmyowner's Avatar
1sttimejimmyowner is on a distinguished road
Default RE:Seafoam
I have used seafoam before and did not see the white smoke like on the youtube video.
I put a bottle in the gas tank and a bottle down the vacume booster line and no white smoke.
Old Nov 3, 2012 | 07:41 PM
richphotos's Avatar
Maybe you just have an incredibly clean engine. Another stupid question, but when you got it started again, did you leave it parked and rev it to 2k rpms?
Old Nov 3, 2012 | 07:50 PM
4x4on20s's Avatar
yea revved it pretty high
Old Nov 3, 2012 | 08:01 PM
richphotos's Avatar
That is odd than LOL
Old Nov 11, 2012 | 10:33 PM
bigzimnh1's Avatar
bigzimnh1 is on a distinguished road
Default Seafoam spray and straw
From what ive read I believe that when you use the vac line method it dont get to all cylinders, just the back 2... I think. Seafaom makes a spray that you can spray into the intake from the throttle body. You have to email seafoam to get a special straw, but they sent me 4 for free. You spray it and let it sit for a few minutes and start it and run it. here is a link to the website. Sea Foam | How to Use Sea Foam Spray | General Content - Sea Foam Spray hope it helps
Old Nov 12, 2012 | 02:01 AM
97cherryblazer's Avatar
97cherryblazer has a spectacular aura about97cherryblazer has a spectacular aura about
Or you just unplug tha MAF sensor and the MAP sensor from the intake then take the intake off the throttle body, start it then SLOWLY pour some down the throttle body.
VRDriver4l
Engine & Internal
13
Jan 2, 2007 04:36 PM
geekdagr8
May 8, 2006 11:04 PM
dion21379
Mar 27, 2006 04:10 PM
tomsblazer
Feb 4, 2006 08:56 PM
khalid_20879
Jan 3, 2006 04:07 PM
