Seal transmission dipsticktube
Old Jul 15, 2017 | 02:20 AM
Snakebite60's Avatar
Snakebite60 is on a distinguished road
Originally Posted by newguy
You can pull the distributor ,just dont turn the shaft at all and you will need to camshaft retard reset
Ok, I will try to get the bolt from underneath, thanks
Old Jul 15, 2017 | 05:50 AM
F*** I hate this vehicle.... to reach the bolt from top is not possible, from underneath the exaustpipes and lines and other stuff make it impossible. I can not even see the bolt..... I have to get an endoscope to find it. $3.00 for the part, and no way to put it in.
Old Jul 15, 2017 | 05:58 AM
newguy's Avatar
The only other thing I can think of is to pull the body monut bolt s on that side and jack the body up a bit to give you some room from the bottom
Old Jul 17, 2017 | 08:02 AM
LesMyer's Avatar
Yeah, It's not easy access, but it can be done with the distributor out and a simple combination wrench - and it's only one bolt. I don't think it is possible to get at this bolt from underneath. At least it wasn't on mine. In the future it would be helpful if you would tell us what year Blazer you are working on. I am assuming a late 1990's - early 2000's second generation Blazer in left hand drive.
I see you have not yet worked on your Blazer much! There are a lot of things like this. FYI there are two other bellhousing bolts that are way more difficult to get out than this one you are speaking about. So my advice is to stop complaining and just do the repair, or pay someone to do it for you. BTW, this bolt is visible from the top on mine.
Old Jul 18, 2017 | 12:37 PM
Thanx, to complain is not the right way. I know a lot of problems when I fixed this car. Believe it, not only a few times. Waterpump, alternator, tie rod ends, transmission sensors, fuel pump and s.o. where the parts for this year so far. And by the way, when the OBD told me to change the tranmission sensors, the mistake was a broken cable to the ignition switch. So I know the little adventures on this car. It is a 1999 model, and it creats only problems, that are not easy to fix. The costs for the parts are ok, but like on other cars a quick repair is most of the time impossible. I think you know what I talk about. So I don't need comments like pay s.o. to fix it. I am here in Germany, we have very good mechanics, but if they see the Blazer, the tell me to fix it self. The call it a Bastelbude. This is hard to translate, maybe I try it later.
And no, I can not see the bolt from top, I got a endoscope and found it. I need to reach to it from underneath, using a camara. I try to post some pictures. Hope that nobody else will have this problem.
Old Oct 5, 2017 | 12:55 PM
Fixed. The way is from top, remove the distributor, remove the heating hoses and donīt have to big hands. This was no fun, but now it is running again.
Old Oct 5, 2017 | 03:31 PM
Transman304's Avatar
Thanks for the update and glad you got it taken care of. Good job!
ElevenevelE
May 4, 2012 12:15 PM
blueblazer2002
Dec 24, 2011 08:32 PM
ANTEC900
May 7, 2011 07:17 PM
litterbug
Mar 7, 2011 09:14 PM
GMC_Jimmy_13
May 4, 2009 01:43 AM
