secondary air system and intake hose
Old Apr 13, 2014 | 01:14 PM
Robt77's Avatar
Robt77 is on a distinguished road
Default secondary air system and intake hose
From what I understand the intake hose for the pump just hangs open under the pump. Is this correct? if so, will a frozen open check valve cause an exhaust leak?
Old Apr 15, 2014 | 10:28 AM
Robt77's Avatar
Default quick fix
I put an extra check valve on the inlet hose until I have time to fix it right, no more exhaust leak.
Old Apr 15, 2014 | 10:32 AM
The intake hose is supposed to run up along the passenger side tank of the radiator. It is not supposed to hang down below the pump.
Old Apr 15, 2014 | 11:15 AM
Robt77's Avatar
I put it in a better location when I "fixed"it. when I do the proper repairs I'll get the replacement hose outlined in the tsb, that was designed to prevent water damage to the pump and put it in that location.
jb34r5e
Oct 8, 2014 08:10 PM
Chevy33
Feb 24, 2012 09:34 AM
XxIRISH63xX
Jan 17, 2011 02:40 PM
Qumodo
Mar 14, 2010 08:33 PM
jjrock5
Jul 31, 2009 03:05 PM
