serpentine belt a.c.
Old May 21, 2020 | 10:13 PM
Czechman90's Avatar
Czechman90 is on a distinguished road
Default serpentine belt a.c.
I have a 96 two door blazer, i seem to be having problems with my belt. When the ac is on the belt starts flapping away,when i turn the ac off it runs normal. The belt is new as well. I hope someone could shed some light on this issue for me.
Old May 21, 2020 | 11:56 PM
What is the condition of the tensioner? It is moving back and forth? It might need to be replaced.
Old May 22, 2020 | 07:16 AM
Czechman90's Avatar
I know the little arrow it has on there isn't lined up with the other one. That might be the thing causing the problem. Don't thos need to be adjusted just right?
Old May 22, 2020 | 08:39 AM
Theres a tensioner spring that will get worn over time. I dont think theres a way to adjust it tho...
Old May 22, 2020 | 09:26 AM
Czechman90's Avatar
I will replace it this weekend, i just haven't turn my a.c. on, i don't want the belt slipping off with it running. The one that is on there has a arrow on it and isn't lined up with the other line. Hopefully it fixes my problem. Thanks for all the help
Old May 22, 2020 | 10:39 AM
I've attached pictures from my 1999 GM Service manual that discuss how to tell if the tensioner spring is not working properly or not. It is likely similar for yours. Good Luck!
File Type: pdf
Old Sep 24, 2022 | 11:59 AM
puttster's Avatar
Thanks Christine. My index mark is on the edge of the indention. I think that is causing the whining.
Edit: Nope, the whining was the idler pulley. Fixed!
Psychropod
17
Sep 16, 2018 03:05 AM
jimspahr@msn.com
Mar 25, 2014 08:45 PM
Cidium
Apr 10, 2011 10:01 AM
92K5BLAZER
Aug 23, 2009 07:01 PM
Blazer_boy
May 18, 2009 10:50 AM
