Service 4wd dash light
Hello all, need help. Just bought a 2001 blazer. 143000 miles in really nice shape. The 4wd worked fine the first 2 weeks. Went in and had radiator flush and fill, transmission flush and fill and had them change transfer case fluid while they were at it. Tranny fluid level is good. A week ago my service 4wd light came on and then went away. It does this here and there now. The problem is it won't go into 4wd. The 2hi button is lit up but won't go in 4 hi, 4 low or 4auto mode. It just stays on 2hi. I hear no clicking sounds or anything when I hit the other buttons. Is this just a bad switch?? Where should I start troubleshooting? When I start the truck and all the dash lights come on all of the lights for the 4wd buttons come on then go off like they should and the 2hi stays lit. Thanks in advance!!!
You can change switch easy fix also check under battery the vacumn line to the transfer case is under there they might have pulled it loose working on the radiatorThats what happened to mine just plugged it back in I did put new line in Worked fine
Also check for corrosion on the TCCM connections , this is also a fairly common issue with these trucks......If you can get the code read with a scanner capable of reading them, it may help in trouble shooting if the switch isn't the issue.
The 4WD controls are pretty trouble free. Lights in the buttons are driven by the TCCM, so their on/off status says nothing about the push button switches. Encoder motors on the transfer case are much more likely to go bad.
Start by reading the diagnositic codes. 3-button controls you use a jumper. 4-button Auto 4wd - you must use a capable scanner.
https://blazerforum.com/forum/2nd-ge...-blazer-89670/
https://blazerforum.com/forum/2nd-ge...-blazer-89044/
fixer34
Jul 28, 2013 10:42 AM
vetteandblazerman
Oct 29, 2009 03:57 PM
