Service Engine Soon light
I've got a 2002 4WD auto blazer. Went to Auto Zone and was told my error code is P0128. They said probably coolant level. Coolant level looks good, heater works just fine and engine temp looks to be well within the normal range. Any help would be appreciated.
Could be a bad PCM coolant temp sensor (engine coolant temp - ECT). There are different sensors for the gauge and the PCM. If the gauge on the dash shows proper engine temp, chances are the t-stat is fine.
amello1
Jan 2, 2006 01:14 AM
TwilightEpitaph
Aug 11, 2005 01:06 AM
gmyoyo
Engine & Internal
Mar 29, 2005 12:17 PM
