Service Engine Soon light
Old Jan 6, 2008 | 07:26 PM
Coldspot's Avatar
Coldspot is an unknown quantity at this point
Default Service Engine Soon light
I've got a 2002 4WD auto blazer. Went to Auto Zone and was told my error code is P0128. They said probably coolant level. Coolant level looks good, heater works just fine and engine temp looks to be well within the normal range. Any help would be appreciated.
Old Jan 6, 2008 | 07:38 PM
chevcamls1's Avatar
chevcamls1 is an unknown quantity at this point
Default RE: Service Engine Soon light
ok that means that your car is running below the temperature the thermostat is supposed toclose maybe the thermostat is stock open and it doesnt close when its supposed to or might be something else
Old Jan 7, 2008 | 05:42 AM
Coldspot's Avatar
So you're telling me it'seitherthe thermostat or something else???
Old Jan 7, 2008 | 06:14 AM
Could be a bad PCM coolant temp sensor (engine coolant temp - ECT). There are different sensors for the gauge and the PCM. If the gauge on the dash shows proper engine temp, chances are the t-stat is fine.
2Blazers
Mar 7, 2006 12:03 PM
amello1
Jan 2, 2006 01:14 AM
alish199
Sep 29, 2005 12:09 PM
TwilightEpitaph
Aug 11, 2005 01:06 AM
gmyoyo
Engine & Internal
Mar 29, 2005 12:17 PM
