service engine soon light blinking constantly
Old Jan 13, 2019 | 09:00 PM
backanforth10to2's Avatar
backanforth10to2 is on a distinguished road
Default service engine soon light blinking constantly
97 blazer 4dr 4wd automatic: replaced cap, rotor and plug wires due to random miss fire code setting. a couple weeks later develops this new problem. idleing rough running rough fuel gauge needle bouncing up and down which seems to correspond to the roughness of the rough idle. needle holds steady under acceleration also needle spikes if i shift back an forth between drive and reverse, drive spikes, reverse spikes, drive spikes and so forth. also the service engine soon blinks continuously steady.
Old Jan 13, 2019 | 09:19 PM
cleburne red's Avatar
The blinking check engine means a severe misfire. Not sure about your other symptoms
Old Jan 14, 2019 | 07:36 PM
go chevy's Avatar
Maybe your fuel injectors need a good cleaning??? Just a thought but try pouring a bottle or 2 of SeaFoam gas treatment in your gas tank next fill up at the pump... I swear by the stuff, it really smoothed out my ride.
Old Jan 15, 2019 | 05:04 PM
go chevy: although i recently replaced the spider and poppets (fuel injectors), i will try the sea foam cleaning since it can't hurt.
cleburne red: im aware blinking service engine soon light might indicate severe misfire (it does indicate other problems) i am interested in answers for my other symptoms.
thank you both for your replies
Old Jan 24, 2019 | 08:54 PM
Matthewrcarrier's Avatar
Matthewrcarrier is on a distinguished road
I had an issue similar to this changed everything plugs, cap and rotor, wires, new cat, fuel pump the whole nine yards it ended up being a worn distributor gear! Take your distributor out see if the gear is worn replace it if so or get new distributor.
Davecubs14
Sep 10, 2015 08:52 AM
Timh310
Dec 9, 2014 08:18 PM
amp042
Jan 2, 2013 04:13 PM
mjink.11
Jan 2, 2013 11:10 AM
Mitchman38501
Jun 16, 2011 01:00 PM
