shaky acceleration
Old Jul 19, 2013 | 09:00 PM
crunklazlo's Avatar
crunklazlo is on a distinguished road
Default shaky acceleration
So I started 2000 blazer z-r2 this morning had almost no gas everything is fine. I go to the gas station fill up the tank and start up, at first it started up really rough and and struggled to accelerate as of something was clogged. I need help!!
Old Jul 19, 2013 | 09:05 PM
rexmburns's Avatar
Super Moderator
Any DTC's come up?
Old Jul 20, 2013 | 06:49 AM
ethan.a.price's Avatar
ethan.a.price is on a distinguished road
Most likely sucked something off the bottom of the tank into your fuel pump or maybe it got past the pump and into the filter. Like rexmburns said... any DTCs? When in doubt seafoam that bad boy.
Old Jul 28, 2013 | 12:28 PM
crunklazlo's Avatar
Okay so I seafoamed my blazer and it looks like nothing helped it, ive also heard this could be caused by bad fuel injectors? I put in new spark plugs about 2 months ago but I feel as I did something wrong. Has anyone else ran into these similer issues?
Old Jul 29, 2013 | 07:49 AM
It's possible you could have cracked the porcelain on one of the plugs. Take a wire off from the distributor one wire at a time. If it gets worse then plug back up and keep going. If you get to a wire where the engine does not run worse then that is your plug.
Old Aug 1, 2013 | 01:27 PM
crunklazlo's Avatar
Update: I sea foamed my truck, replaced the fuel filter, and checked all my spark plugs everything looks good. In the mornings I still get the shaky acceleration but by the time I get off work it runs perfect. The only other known problem is that I need a catalytic converter, could that be my issue? Amd has anyone else had this happen to them?
tdbone1
Dec 20, 2012 09:40 AM
santmire
Oct 12, 2009 11:42 AM
Canadian88
17
Jun 24, 2008 06:38 AM
joey
Dec 17, 2006 09:47 PM
Blazin 4x4
Oct 14, 2005 01:03 PM
