she won't start!
Old Aug 16, 2015 | 10:10 PM
captblackleg's Avatar
captblackleg is on a distinguished road
Default she won't start!
I've had the problem of no fuel pressure when trying to start the motor, I've just had everything check, they got it going but now it won't start at all. Can this be the fuel pressure regulator?
Old Aug 17, 2015 | 09:26 PM
Ricco's Avatar
Ricco is on a distinguished road
Is ur pump working? If so is ur fuel pressure dropping? After a few minute? What exactly you mean by had everything checked? Timing, fuel pressure, spark, compression?
Old Aug 17, 2015 | 09:56 PM
Yep, been through 2 fuels pumps, the first one had a fault in it, I've got no fuel pressure at all on a cold start. The new pump has been checked and is fine, only thing I can think of is the fuel pressure regaultor
Old Aug 17, 2015 | 10:03 PM
Ricco's Avatar
If it drops pressure after switching off your ig it could be a possibility, theres a few step procedure to check a regulator malfunctioning. Also check your pressure as it cranks, maybe a old fuel filter its dropping ur psi as you crank? Just trying to give you ideas
Old Aug 17, 2015 | 10:06 PM
I found a mechanic who is a wiz with blazers, sending it off to him to sort, this all over my head, don't know what hell it all does, just want it to work
Old Aug 17, 2015 | 10:19 PM
Ricco's Avatar
I hear you, I been there. good luck my friend. Keep us posted on what he find, I would like to see the answer
hemivette
Jul 23, 2012 04:31 PM
danzy555
Sep 12, 2009 02:44 AM
mysons95
Oct 17, 2008 09:42 AM
XBlazer01
Nov 11, 2006 06:37 AM
michellesmark01
Engine & Internal
Jan 21, 2006 07:30 AM
