Shifting into neutral
Old Apr 14, 2013 | 03:05 PM
chadd77's Avatar
chadd77 is on a distinguished road
Default Shifting into neutral
I have a 1997 blazer 4WD. Just recently my blazer shifts into neutral after 2nd gear. If I let my speed come back down it shift back into 2nd gear. I can't go much faster the 35 mph. Even if I shift on the column the same thing happens - after 2nd gear it go into neutral. Any ideas? No service or check engine light is on. Any help is appreciated.
Old Apr 16, 2013 | 12:15 PM
chadd77's Avatar
Is there a way to scan the computer and get some info back on my issue if there are no service lights currently on?
Old Apr 19, 2013 | 10:10 AM
chadd77's Avatar
I did a ton of research but still unable to find a solution to my issue. Another member here seemed to have the exact issue as I am having but he never reported back to say what the fix was. Can anyone help??
Old Apr 19, 2013 | 10:16 AM
chris015's Avatar
u sure its going into neutral? Sounds to me like 3rd is gone and its just slipping.
Old Apr 19, 2013 | 10:51 AM
chadd77's Avatar
Very well could be. It doesn't do it all the time. Seems like after it is running for a little while the issue goes away. But I haven't been driving it all that much due to the problem.
If 3rd gear is gone or is about to go what can be done to fix it?? New trans?
Old Apr 19, 2013 | 12:45 PM
chris015's Avatar
pretty much a rebuild yea. If you go this route make sure you tell em to beef it up a tad,with a beast sunshell.
Old Apr 19, 2013 | 01:28 PM
chadd77's Avatar
How much do rebuilds usually cost??
Old Apr 19, 2013 | 02:02 PM
slcblazer's Avatar
slcblazer is on a distinguished road
400-600 ish... at least here in Utah
S15JIMMY
Feb 1, 2014 07:13 PM
Eldawg
May 6, 2013 11:24 AM
Adrienne3889
Feb 22, 2012 12:50 PM
mxboy96
Jan 5, 2010 06:31 PM
96jimmy4x4in
Oct 7, 2007 09:23 PM
