Should tranny fluid be changed after 200k miles?
Old Dec 26, 2017 | 12:58 PM
medicineman2011's Avatar
medicineman2011 is on a distinguished road
Default Should tranny fluid be changed after 200k miles?
I have about 200k miles on my 98 truck and I have never done a transmission oil change. Someone said that it may hurt it worse if you change it after that many miles. It stills works ok, but I'm thinking preventive maintenance. I know my dipstick is rusty looking.
Old Dec 26, 2017 | 02:01 PM
Snap-Off's Avatar
Snap-Off is on a distinguished road
That transmission fluid change will cost around $2000+ by the time all is said and done. Most shops wouldn't touch it because they know that you will probably not be able to drive the vehicle away afterwards.
Old Dec 26, 2017 | 03:23 PM
newguy's Avatar
dont do it if its never been done or you dont know the history.
Old Dec 26, 2017 | 03:31 PM
chevyriders's Avatar
Don't do a flush. Most of the time it will end up needing a rebuild afterwords(as has already been stated).
Dropping the tranny oil pan, draining what's in there, changing the filter and gasket , and replacing the atf that was drained would be good a good service to do though...and that'll probly cost less than 20 dollars and an hour of your time.
Be aware that there are 2 different depths of tranny oil pan, and you need the correct filter for your depth pan.
Old Dec 26, 2017 | 04:25 PM
My owners manual says that the ATF should be replaced with a new filter ever 50,000 miles. My transmission shop charges just under $200 for the fluid and filter change.
Why not do the service?
Old Dec 26, 2017 | 04:34 PM
Snap-Off's Avatar
If the ATF gets flushed out , all the grit and debris also gets flushed out.. After so many miles with the original ATF , this grit and debris is now what provides friction to the clutch packs.
Most of the time, after a tranny flush , it starts slipping and then just goes downhill from there real quick.
Old Dec 26, 2017 | 04:59 PM
newguy's Avatar
Mine slipped without the flush, just a change did it.
Old Dec 26, 2017 | 05:10 PM
Snap-Off's Avatar
Same happened on my '89 IROC with 700R4... And to my bud's Honda..In fact He had the ATF changed in his 2nd Honda and the same thing happened...Took him two times to learn.. Expensive lesson to learn..
Old Dec 26, 2017 | 06:01 PM
Just draining the pan? Or having the old fluid pushed out and new put in with the machine?
I've never had an issue with just dropping my pan before, done it a ton of times, and all my buddys do regularly on their chevy trucks too. Never seen it cause an issue.
The machine will cause an issue almost every time on gm products in my experience though
Old Dec 27, 2017 | 02:50 AM
newguy's Avatar
yep, just dropping the pan
