Should tranny fluid be changed after 200k miles?
Old Dec 27, 2017 | 09:29 AM
rriddle3's Avatar
I would not want to go over 50K without a fluid change. After 200K on original fluid - forget it.
There are two basic types of transmission flush machines - one that uses its own pump to power the flush and the other type uses the trans' own pump to move the fluid. The latter is perfectly safe for any modern transmission, but I have never had an issue with the former type, either. As for just dropping the pan, if all you want to do is change about 1/4 of the total ATF in the system that's fine, but I prefer to replace it all with fresh fluid.
sillyak
Aug 19, 2013 12:48 PM
JasinP
Jun 1, 2011 10:09 PM
96realwe
Dec 10, 2010 09:19 AM
navyblue_sk8er
Feb 22, 2008 09:17 PM
LT1KICKER
Oct 23, 2006 04:00 PM
