Smell of gas
Old Nov 26, 2013 | 01:56 PM
tbernard113's Avatar
tbernard113 is on a distinguished road
Default Smell of gas
I have a 98 blazer that after running for a while you get an oder of gas when you walk by checked the gas tank lines everything is intact it starts hard wondering if the spider injector could cause the smell along with the hard starting and info would be helpful
Old Nov 26, 2013 | 05:16 PM
Diaita's Avatar
A leaking fuel pressure regulator/injector assy sounds like a likely problem.
Old Nov 26, 2013 | 06:04 PM
1sttimejimmyowner's Avatar
1sttimejimmyowner is on a distinguished road
agree injector/s ,could also be where the fuel lines connect into the top of the spider and fuel regulater.Also since the fuel lines run underneath the frame you may have a hidden leak.Also check around the fuel filter a common rust area that causes leaks.
Old Nov 27, 2013 | 12:02 PM
Dark Rider's Avatar
Dark Rider is on a distinguished road
Check the charcoal canister.
Old Nov 28, 2013 | 01:42 AM
Thogert's Avatar
**Moved to engine and transmission**
trapperjohn4077
Jun 7, 2010 10:49 AM
chrisblaze
May 23, 2009 02:21 PM
metalhead
Mar 1, 2007 12:46 AM
hollisterdj
Dec 1, 2005 03:22 PM
ShadowHawk
29
Oct 23, 2005 01:50 AM
