So Lost...Someone Pls Help
Old Mar 29, 2011 | 02:45 PM
ChevyTruckKindaGirl915's Avatar
ChevyTruckKindaGirl915 is on a distinguished road
Talking So Lost...Someone Pls Help
Ok I need some help cause this ghost in the system of my truck is kickin my tail end.
I have a service engine light on in my truck, reads a random misfire code, but reverts to the crank sensor, we changed the shim, the code changed, but its still a random misfire
shes hard to start and she idles rough, but we just did the plugs and the wires and like i said before the codes kickin back something regarding the crack sensor. idk what is going on with my baby truck but shes been thru enough already...
someone pls help me
if it helps:
shes a 2002 Chevy Blazer LS 4WD 4Dr
Old Mar 29, 2011 | 03:32 PM
rriddle3's Avatar
What exactly are the code numbers you're getting?
Old Mar 29, 2011 | 03:57 PM
i would have to get them from my dad, i will post tomorrow...keep an eye out
Old Mar 29, 2011 | 11:54 PM
Cidium's Avatar
Cidium is on a distinguished road
Sorry for adding some non-sense to this post but when I read " idk what is going on with my baby truck but shes been thru enough already..." I just started laughing. Not because of your truck having problems, rather everyday I say to my blazer, " I just spent another 50 bucks on you and that's all you get!" Honestly, if I didn't have something to fix, tinker or just outright replace I might get bored. good luck~
Old Mar 30, 2011 | 12:09 AM
Little Roober's Avatar
Little Roober is on a distinguished road
Or finally be able to use that savings account...
Old Mar 30, 2011 | 11:30 AM
LowLife's Avatar
LowLife is on a distinguished road
Hmm starts hard, idles bad....ever check the fuel pressure, or even if the pressure is good the fpr could be going bad or your injectors im pretty sure 02 had the old poppet injectors that would definatly cause a random misfire. Just a thought
Old Mar 30, 2011 | 08:05 PM
kristoph30's Avatar
kristoph30 is on a distinguished road
Changed plugs and wires.....how about cap and rotor?
Old Apr 1, 2011 | 12:57 AM
Blaze the S10 4x4 Blazer's Avatar
Blaze the S10 4x4 Blazer is on a distinguished road
I would check the egr for rough idle problems and of course the three sensors for continuity (tps, iac, and map) all those affect idle. Coil could be bad so check that to I usually like to look for spark color, seems to work for me. (blue or white= strong spark) (anything else= weak spark)
Old Apr 1, 2011 | 08:37 AM
kristoph30's Avatar
I would stick to basics first. If the cap and rotor are bad, it will cause all of what is being described. I bought a truck that had "so many problems it wasnt worth fixing" for $500. I tuned it up and I have been driving it ever since. (Cap rotor, plugs and wires.) The shop that condemed the truck had determined that the ENTIRE injection system had to be replaced. Nice. Before you start dumping money into the truck based on the codes you pull, PLEASE verify the basics are in line. (Fuel pressure, Ignition system, mechanical condition of engine.) Collect all that info, and you will have some good hard facts as to what is wrong with it. Good luck!
PhillyZ
Oct 6, 2009 02:10 AM
1986k5blazer
May 26, 2009 06:54 PM
blazerluv
Mar 26, 2009 11:14 AM
tyrant46whtcobra
Sep 7, 2008 08:00 PM
nitrous2126
Nov 7, 2007 01:59 PM
