somehting wrong, Transfer Case?
RE: somehting wrong, Transfer Case?
so it turns out, i had no oil in the front diff, i havnt pulled out the diff yet but i'll probably need to change the bearings and if the gears are no good, i'm stuck getting a whole new diff. The grease everywhere is cause i have cracked boots.
Thx for the help tho guys.
That is not good! Maybe fill the front diff and see how it sounds..?
I filled it and it sounded fine, but that was temporary...just long enough to get my hopes up, then the grinding continued, i probably need a bearing kit, worst case scenario a pinion set aswell. but i wont know till i take it apart. But i know its gonna be a costly fix.
but i guess **** happens eh?
So just got the Blazer fixed, cost me a whopping 1700$ wich was the money i was planning on lifting my truck with and then more.
some of the bearings in my front differential had melted slightly and warped, and they took out the pinion gear.
Flyfishen
06-18-2019 11:22 AM
bensaintonge
12-03-2013 08:14 AM
kyle123
04-03-2010 05:13 PM
loscochinos520
05-28-2005 11:32 PM
