Sounds like my 02 Blazer has a supercharger but definitely doesn’t
Old Dec 5, 2019 | 05:27 PM
Linus Hulet's Avatar
Linus Hulet is on a distinguished road
Default Sounds like my 02 Blazer has a supercharger but definitely doesn’t
My blazer (LS 2002 2WD 4.3 vortec) sounds like it’s supercharged whenever I get to high rpms. Any ideas??
Old Dec 5, 2019 | 06:12 PM
Clogged air filter, or air getting into the intake tubing somewhere it's not suppose to?
How high of RPMs are we talking about here? How loud is the sound? Any chance you could post a video?
Old Dec 5, 2019 | 08:30 PM
i just changed the air filter and it’s still making the Noise, it gets you about 4000rpm and that’s when it gets loud enough to really hear it. Let me see if I can post a video and get a link for it
Old Dec 5, 2019 | 08:34 PM
https://drive.google.com/file/d/1YCJ...w?usp=drivesdk
Old Dec 5, 2019 | 08:50 PM
odat's Avatar
Sounds like belt and fan singing - imo sounds pretty much normal for just revving the heck out of the engine sitting in park/neutral ....
Old Dec 5, 2019 | 09:30 PM
Honestly to me, that sounds like alternator wine.
Old Dec 6, 2019 | 12:28 PM
well it does it while driving too even when I don’t go super high rpms it’s just louder the higher rpms it gets
so then I’m guessing I shouldn’t worry about it?
Old Jan 5, 2020 | 01:48 PM
Michael J Wyskida's Avatar
Michael J Wyskida is on a distinguished road
I had the same thing in my 99 blazer it was the idler pulley bearing. You can get a new pulley from advance auto for 20. And it takes 10 min to swap. When I took the old pulley off you could definitely feel the roughness when spun it
Old Jan 5, 2020 | 02:41 PM
Jimmybuild's Avatar
Jimmybuild is on a distinguished road
I would recommend you pull the belt off and spin your pulleys. Check for any growl or play. Can get some pretty strange noises from those guys.
Old Jan 9, 2020 | 09:54 AM
jimspahr@msn.com's Avatar
It could be a bad Fan clutch. Rent a 36 mm wrench and you can take it off and the 4 bolts that hold the hub on. Check the fan clutch first.
