Squeaky Engine?
Old Aug 17, 2011 | 07:25 PM
brently04's Avatar
brently04 is on a distinguished road
Default Squeaky Engine?
The engine seems to run okay but there is a squeaky sound coming from it. Maybe the timing belt? too loose? or oil on the timing belt? Anyone have any ideas?
Old Aug 17, 2011 | 07:29 PM
Your engine has a timing chain, not a belt. The accessory drive belt can and often does squeak on these engines. Have you ever replaced it? I have always had good luck with the goodyear gatorback belts.
Another possibility that has cropped up on here for one other member is a malfunctioning PCV system. PCV = positive crankcase ventilation. If there is a problem with either the PCV valve or the fresh air makeup tube, crankcase pressures can get excessive and cause a squeaking noise.
Old Aug 17, 2011 | 07:41 PM
brently04's Avatar
Thanks for the quick reply!
Im not sure if it has ever been replaced I just bought this truck today. Should I just check the accessory drive belt for wear or anything? Ill be honest dont know a thing about these vehicles. First truck ive ever owned. And love it lol
Old Aug 17, 2011 | 07:45 PM
It is very difficult to see wear on the newer belts. I would replace it and coil up the old one, tossing it in the back of the truck. Never know when a belt will decide to break and it's handy to have another one there with you if it does happen.
Old Aug 18, 2011 | 10:02 PM
brently04's Avatar
good advice, thanks! will get that replaced one I get the rust taken care of
tonedef132
Nov 4, 2009 07:20 PM
ChevyMan90
Aug 22, 2009 03:03 AM
Kaffeene
Jun 21, 2008 11:34 AM
03blazer
Apr 9, 2008 03:27 PM
sprint777
Apr 6, 2006 06:18 PM
