Squealing sound and symptoms
Old Dec 27, 2023 | 02:24 PM
HDmechanic1's Avatar
HDmechanic1 is on a distinguished road
Unhappy Squealing sound and symptoms
I have been hearing a squealing noise for a few weeks now. I can hear it when I start my 1995 blazer and when I am driving. It sounds similar to the sound when your brakes start to go bad, but it is not the brakes. It comes from the engine area. It is constant, whether on the streets or the freeway, it sounds the same. Does not change with engine speed, except when I am stopped, it stops. In 2021 I purchased a remanufactured a/c compressor and installed it. My air conditioning is working great, haven't noticed anything going on with it. Could this sound be related to the clutch bearings going out? Would I hear the noise first before any symptoms in the a/c occur? What symptoms would occur if the bearings were bad? I just listened to it right now and it sounds like a rotational squeak when it is in park and idling.
Old Dec 27, 2023 | 05:23 PM
GeorgeLG's Avatar
Buy or make a stethoscope out of a tire iron, pipe, metal rod, etc, hold one end in your fist, put the other end on each rotating item, place your ear against your fist and compare the volume and vibration on each item. Be careful everything is rotating.
George
Old Jan 6, 2024 | 06:33 AM
cartercarbaficionado's Avatar
cartercarbaficionado is on a distinguished road
spray your belt with water or wd40 to see if the squealing stops, if it does then its not your ac compressor its something else, once it starts squealing again take a video of the belt and spray water at it since I'm trying to see if it's doing what mine did before it killed its water pump
Old Jan 7, 2024 | 12:33 AM
Thanks for the suggestion. I will try it tomorrow and let you know what happens.
Old Jan 7, 2024 | 05:32 AM
dsk's Avatar
dsk
dsk is on a distinguished road
Did you say that it only happens when you are moving? If so, I would suspect the drivetrain and not the engine.
Bad hub or CV maybe?
HFordFett
Jun 1, 2017 02:44 PM
WolfPack
13
Apr 7, 2011 02:51 PM
deadbuzzard
Aug 5, 2009 03:34 PM
joe_zish
Jun 14, 2009 08:59 PM
willjones
Mar 6, 2008 06:21 PM
