Started Pulling.
ORIGINAL: Jharper
Chevy didnt produce the vortec until 95 or 96 (not exacly sure) but the motor came out of a 94 s10, it does not say vortec anywhere on it, and the intake is way different then both the vortec virsions. im returning it to get my money back and just rebuild mine.
Your '94 block will work fine, however you will need to use your '96 heads and intake manifold. GM did change the angle of the intake manifold bolts into the heads in '95 or so.
Also since you ahve a '94 it should have roller, and it may or may not have a balance shaft. More then likely does, look for it under the intake manifold. GM started putting them in the 4.3 in '93.
Here is a better article with more information.
http://www.babcox.com/editorial/ar/ar39840.htm
i resized them and it still wont work for me, whats the deal?
EDIT: okay i added the pics to my photo album. heres the link https://blazerforum.com/albumphoto.a...=1&apage=1
Good luck to you with your rebuild and man youve got a nice GTP. I was gonna get one but decided on a blazer instead because I do a lot of camping and tonnes of fishing, plus a blazer is better with the little one too.
scottyk
Feb 27, 2007 11:51 PM
oshkosh
Jan 27, 2007 01:22 PM
