starter disaster......
Old Nov 27, 2013 | 09:17 AM
thomas80's Avatar
thomas80 is on a distinguished road
hello, i have recently had to drill and tap both starter mounting holes and i went up in size to 7/16 using heli coils. to make matters worse the ear of the outside hole has been snapped off. the vehical is a 1997 awd blazer 4.3l vortek. the starter will mount up tight but however its not catching,just a little scrape then spins. any ideas would be helpfull. i realy would hate to get rid of my truck over a starter.thanks!
Old Nov 27, 2013 | 09:44 AM
newguy's Avatar
If it bolts up tight AND lined up, sounds like a starter issue
Old Nov 27, 2013 | 09:50 AM
Jamaroon's Avatar
The ear on the starter is broken off?
Are the teeth on the starter stripped? Or the flywheel?
Might be best to replace the starter if the ear is broken off, if the teeth are stripped then you really need to replace the starter. If the flywheel teeth are stripped then it's a bigger repair.
Old Nov 27, 2013 | 09:53 AM
thomas80's Avatar
its not lined up properly and i need some ideas on how to line it up. it seems as if its about 1/8 away from the wheel towards the outside of truck
the ear on the block is broken. teeth are fine on starter and flywheel. it seems like the starter is to far away from the flywheel. any ideas on how to get it closer
Old Nov 27, 2013 | 10:13 AM
newguy's Avatar
adapt a bigger gear onto the starter?
or get the starter lined up and weld it on
Old Nov 27, 2013 | 10:19 AM
thomas80's Avatar
adapt a bigger gear on starter sounds like a good idea but is it possible to do and where would i find such a thing. welding would be an option but can you weld aluminum to steel
Old Nov 27, 2013 | 10:23 AM
jpimp's Avatar
jpimp is on a distinguished road
if the holes on the engine block are to far back now, maybe grinding larger holes into the starter will allow you to bolt it up closer to the flywheel with the holes currently on the truck
good luck
Old Nov 27, 2013 | 10:28 AM
thomas80's Avatar
good luck
i will give that a try and thank you. i am a little worried about the nose cone snapping if i take away its material but i am at a point where i have to try anything i can. i like my truck and dont want to loose it over this
Old Nov 27, 2013 | 10:54 AM
newguy's Avatar
Dude your not gonna lose it. If anything bring it to a garage
Old Nov 27, 2013 | 11:19 AM
thomas80's Avatar
do you happen to know if there is a starter that will have the same gear but also have larger mounting bracket?
