Starter Noise in 97 Blazer
Old Dec 20, 2010 | 11:47 AM
peterbilt64's Avatar
peterbilt64 is on a distinguished road
Default Starter Noise in 97 Blazer
Put a new flywheel in my 97 Blazer and now the starter makes a grinding and clunking noise. It did not do it with the old flywheel. Any idea
Old Dec 20, 2010 | 11:48 AM
Did you match up the new and old flywheels to make sure they were identical in terms of # of teeth as well as offsets? Also, did you install it in the same orientation as the original (in terms of front/back orientation)?
Old Dec 21, 2010 | 06:19 AM
Default flywheel
The flywheel is the same, 168 teeth. It is also installed correctly. I have put them in before and never had this problem. There is only 1 flywheel for this vehicle
Old Dec 21, 2010 | 06:52 AM
You may just have to shim the starter to get it to mesh correctly then...
Old Dec 22, 2010 | 10:16 AM
Default starter noise
I tried 3 sizes of shims and it made no difference. I also replaced the starter and that made no difference. Any other idea would be a great help.
Old Dec 22, 2010 | 10:20 AM
Other than what I originally mentioned, there really aren't many more things it could be. I believe there are different offsets in the flex plate so if it is installed backwards, it would result in the ring gear being out of position.
You could measure from the center of the starter bolt hole closest to the bell housing back to the back of the ring gear (side closest to the transmission), then compare that measurement to the same bolt hole on the starter out to where the bendix moves the drive gear to (manually extending the bendix). These measurements should end up being equal.
If that checks out, then the flex plate may not be the proper size (tooth count)...
I know you said that those two things were verified, but there isn't much more to it.
jdmmario
Oct 25, 2014 06:25 PM
offskooring
Jul 31, 2009 07:59 PM
joey
Feb 15, 2007 08:08 AM
LoLoS10Blazer87
Dec 16, 2005 12:18 AM
blazergirl15
Aug 28, 2005 11:17 PM
