Starter won't turn engine
Old Dec 5, 2016 | 11:01 AM
Tjohnson145's Avatar
Tjohnson145 is on a distinguished road
Default Starter won't turn engine
Hello
I have a 99 jimmy 4x4 with a V6. I have had problems getting it to run. I have a new battery and starter. But for some reason I can't diagnose why the starter hits and try's to turn the motor but can't. I can see the serpentine belt move slightly. Any suggestions would be great
Old Dec 5, 2016 | 11:37 AM
LesMyer's Avatar
Originally Posted by Tjohnson145
Hello
Is the motor locked up? Can you turn it over with a socket on the crankshaft pulley? Remove all the spark plugs and try it again - it could be hydrolocked as well. Be careful don't break the bolt off in the crankshaft.
Old Dec 5, 2016 | 01:22 PM
Thanks for the response. Yes I can turn the crank. I will try removing the spark plugs.
Old Dec 6, 2016 | 05:51 AM
LesMyer's Avatar
If you can turn the crankshaft with a socket then no need to pull spark plugs.
turn the headlights on. Do they go out when you try to crank the engine with the starter?
Old Dec 6, 2016 | 07:59 AM
The motor was hydro locked. But it's a good thing I pulled the plugs. 4 out of 6 fell apart. I was told they were replaced by the previous owner.
Old Dec 6, 2016 | 11:23 AM
LesMyer's Avatar
Glad you have it figured out! Thanks for letting us know.
jdmmario
Oct 25, 2014 06:25 PM
Jason10476
Jan 26, 2014 07:47 PM
amp042
Jun 9, 2013 04:29 AM
andrewrj
May 6, 2012 07:28 PM
justcuz
Jul 18, 2008 08:17 PM
