Starting up a motor that has sat for about a year
Old Jul 24, 2007 | 04:36 PM
Philly Assassin's Avatar
Philly Assassin is an unknown quantity at this point
Default Starting up a motor that has sat for about a year
I have a 90' 4.3L S10 Blazer that has sat for about a year now due to front end damage (accident with a guardrail). The truck is just about fixed up now after a long period of procrastination. What procedure should i do to have my motor fire right back up. I know to drain the tank/lines and change my fuel filter. What else do i need to do??
Old Jul 24, 2007 | 04:52 PM
Default RE: Starting up a motor that has sat for about a year
I'd pull the plugs and squirt in some oil. Then turn over the engine by hand a few revolutions. Then with the plugs still out, turn it over with the starter to build the oil pressure up. Once you have oil pressure, put the plugs back in and have at it.
Old Jul 24, 2007 | 07:39 PM
rriddle3's Avatar
Plus, after having the engine at operating temperature for about 5 minutes, change the oil and filter.
Old Jul 24, 2007 | 11:57 PM
Chevy Lover's Avatar
I hope you have a fuel stabilizer in the tank. Hopefully the tank is low and you can add some fresh gas.....just to add to the 2 previous posts, with which I also agree.
Stormedsoup
Mar 13, 2013 12:21 PM
Cwill3
Feb 26, 2013 11:29 PM
mansopoor
Sep 26, 2010 07:35 PM
Scrapmetalbandit
Sep 21, 2010 06:05 PM
ml8163
Nov 8, 2008 08:25 PM
