Starts, dies when gas is applied...
Old Feb 23, 2009 | 10:54 PM
KK808's Avatar
KK808 is an unknown quantity at this point
Default Starts, dies when gas is applied...
I don't know much about blazers, but i recently got a 1990 s10, or t10 wich ever is 4x4. 4.6L engine.
about a month ago the engine strting getting weaker and weaker. one day it wouldn't even move. it seems to move until it warms up.
i have put a new: ditributor, new computer (twice), Map Sensor, spark plugs/wires, Checked the injectors, Checked the fuel pressure, New rotor cap, and i checked the throttle body.
i have heard some comment about the injectors/harness maybe being grounded out. i have yet to check this, as i do not know how.
please send me your thoughts, i really want to keep this truck but i have a deadline of 1.5 months or i have to get rid of it.
-Nathan
Old Feb 24, 2009 | 05:00 PM
millertymemusic's Avatar
millertymemusic is an unknown quantity at this point
Default RE: Starts, dies when gas is applied...
check catylitic converter
Old Feb 24, 2009 | 08:41 PM
Leeann_Bravada's Avatar
Leeann_Bravada is an unknown quantity at this point
S = 2dr
T = 4 dr
Your engine is a 4.3L.
What does the tranny fluid look/smell like? Where is it on the stick when it's warmed up?
Old Feb 24, 2009 | 09:39 PM
Hanr3's Avatar
Get your TPS (trottle postion sensor) and IAC (Idle air control) tested.
Is this a TPI or TBI fuel injected motor?
Old Feb 24, 2009 | 10:44 PM
KK808's Avatar
yeah thanx guys, mistake on that, it is a 4.3L, my mistake. and it's a 2dr.
thanx il try al of these, keep sending me ideas plz.
-nathan
Hanr3 this engine has TBI injectors
Old Feb 24, 2009 | 11:01 PM
Hanr3's Avatar
Make sure both of them are firing.
It could be your main injector isn't working. There should be one for idleing, when you give her gas the main one takes over.
Are you getting a Check Engine light, have you had the codes read? Codes would be hte best source of information. No codes generally means a fuel delivery issue. The puter assumes your getting proper fuel delivery. It doens't monitor fuel pressure or fuel delivery.
Old Feb 25, 2009 | 06:54 AM
ORIGINAL: Leeann_Bravada
S = 2dr
T = 4 dr
Just to clarify, S = 2wd & T = 4wd. If the search feature was working properly, I would dig up the thread where we got more in depth in the designations than just that.
Old Mar 4, 2009 | 07:14 AM
Just to bring this back.
Disconnect the O2 sensor and remove it from the exhaust pipe. Then start the truck and see if it exhibits the same problems. If the problem is gone, then your catalytic converter is at fault.
Old Mar 7, 2009 | 03:06 AM
warrenwheeler's Avatar
warrenwheeler is on a distinguished road
Default It's your Catylitic Converter I'm 100% sure!
Change the Cat. Conv. or drill a 1\2" hole before the Cat.Conv. and your Blazer will come back to life...
-Nathan
Old Apr 12, 2009 | 01:13 PM
okcdan's Avatar
okcdan is an unknown quantity at this point
Originally Posted by Leeann_Bravada
S = 2dr
T = 4 dr
interested in why you asked this question about the fluid? i have this problem of major hesitation when accelerating, uless i "feather" the pedal in a certain way - the blazer will die. i've been chasing a TPS problem - if i'm checking it right, there is no voltage at the connector whatsoever. BUT, the other day while i was under the hood with it running, i decided to check tranny fluid, and it showed on the stick to be extremely overfull, to the point that i didn't really believe it could be correct...
