Stripped flex plate bolt heads
Old Jun 1, 2020 | 05:07 PM
Juggalonmd's Avatar
Juggalonmd is on a distinguished road
Exclamation Stripped flex plate bolt heads
Ok so I'm trying to get to rear main seal and I finally get transmission lowered and backed away enough to get to flex plate and come to find out that 2 of the six are rounded and a third that's border line. I've tried using a lil torch I have to get some heat on it. I've tried getting vice grips on them I get a bite but it doesn't last long. I've tried beating the bolt with a flat head screwdriver. Spayed the cuss out of it with some pb blaster after getting it hot and then hitting it with a hammer and putting a wrench on it. Then this morning went to Lowe's and got the gator bite socket. Still nothing. I've thought about a pipe wrench but don't have one around small enough to take the bite. I'm trying not to have to cut the head off. I'm broke and can't afford to get any easy outs. Please anybody have a good if not ful proof way to remove these bolts? I'm stuck and frustrated. Thank you in advance
Old Jun 1, 2020 | 05:41 PM
Have you tried to weld a bolt to the bolt and wrenched it off??
Old Jun 1, 2020 | 05:47 PM
Juggalonmd's Avatar
No but I don't have a welder either.
Old Jun 1, 2020 | 05:50 PM
Bummer, too bad portable welders haven't became a thing yet. Any friends with one? Sorry but it's an option...
on a side note, is the name icp related?
Old Jun 1, 2020 | 05:53 PM
Juggalonmd's Avatar
Yea no it would be a good one I appreciate u trying to help. No one i know that is mobil
Old Jun 4, 2020 | 10:18 AM
Juggalonmd's Avatar
[QUOTE=Juggalonmd;723014]Yea no it would be a good one I appreciate u trying to help. No one i know that is mobil[/QUOTE
Yes it is been down with the wicked clowns since early 90s.
Old Jun 4, 2020 | 10:22 AM
Juggalonmd's Avatar
So finally was able to get a good torch and got flex plate off doing some cleaning on retainer and hope to have it together by noon. Then its ball joints. And my project will be done for now. Hoping I won't need an alignment. But I just seen a vid that tell the diyers like me how to do so. Luving my Chevy!! Hope everyone is doing good and healthy
Old Jun 4, 2020 | 11:33 AM
That's awesome! Could always point our own out lol.
glad the bolt came out for the work done, as long as you dont mess with the tie rods too much, you should be good without needing an alignment.
good luck, I'll be doing balljoint/tierods/idle arm on the moms jimmy tonight after work.
echo1
15
Aug 28, 2012 07:56 PM
burnout350
Lifting Tech
May 22, 2012 01:16 PM
4thgenceli
Feb 26, 2011 06:26 PM
urbex
Nov 27, 2009 06:17 PM
wraithklewn
Aug 21, 2009 11:19 AM
