Swapping a 94 4.3 and trans into a 95 blazer
Old Aug 25, 2010 | 05:50 PM
white95blazer's Avatar
white95blazer is an unknown quantity at this point
Default Swapping a 94 4.3 and trans into a 95 blazer
Ok I have a 95 4x4 blazer with a blown motor and I found a 94 jimmy for pretty cheap that has a good motor and trans. I want to swap the 94 jimmy 4.3 and trans into the 95 blazer. Is this possible? I'm searching but not finding much info, any help is really appreciated. Oh and they both have the orange vortec intake.
Old Aug 25, 2010 | 05:59 PM
Ryanmatt135's Avatar
Ryanmatt135 is an unknown quantity at this point
um, im not sure, the 94 will be running obd1 and the 95 runs "obd 1.5" so it may work. i would just check your electrical connectors on the tranny and engine and make sure all of them match up (make sure all of the connectors are the same shape). and then i would look at the tanksmission linkage and see if that looks the same.
Old Aug 25, 2010 | 07:08 PM
The ONLY way this would work is if the 95 transmission you removed does not say PWM on the front of the pump cover (behind the torque converter) or if the '94 trans did have it somehow. If your old trans says PWM and the old one does not, they are not interchangeable.
Old Aug 25, 2010 | 07:36 PM
If I couldn't use the trans, then could I use the motor? I will check tomorrow and see if the 95 blazer trans has the PWM on it or not. what does PWM stand for?
Old Aug 25, 2010 | 07:39 PM
Isnt it pulse with modulation?
Old Aug 25, 2010 | 07:47 PM
Yep. PWM = pulse width modulation which is how the newer transmissions regulate TCC lockup.
Old Aug 25, 2010 | 08:08 PM
so tcc lockup on a pre 95 4l60 was controlled by hydros?
Old Aug 25, 2010 | 08:16 PM
No. It was either locked up or not. Sometime in 95 they added variable lock up using a PWM signal.
Old Aug 25, 2010 | 08:22 PM
oh. intresting. off topic, i could have used your help this past weekend, i was up in waterloo, comming home from the outlet mall on 318 and my coil died on me, i was able to test the circut with a light bulb i had and no spark. so had to get a tow. PITA! where abouts do you live in waterloo, maybe next time im up there i can check out the K5!
Old Aug 25, 2010 | 08:44 PM
*offtopic* Just a bit south on Rt 96 or Rt 414, whichever way you want to look at it. I live on County House Road. */offtopic*
rickward
Jun 24, 2015 07:23 PM
Mi99z71
Oct 7, 2013 06:33 PM
siccnezz
Mar 20, 2011 09:33 AM
jsjeepie
Aug 13, 2010 08:31 PM
behemoth
Jun 23, 2009 06:13 AM
