Tasking Transmission
Old Dec 31, 2012 | 03:22 PM
superman3801's Avatar
superman3801 is on a distinguished road
Default Tasking Transmission
This morning lost drive with no indication that it was coming. There was no slipping no hard shift, nothing. Still have reverse 1st and 2nd with no issues. What the H#&%?
Old Jan 1, 2013 | 12:21 PM
rriddle3's Avatar
It's going to be difficult to help you if we don't know what you're driving.
Old Jan 1, 2013 | 12:25 PM
Sorry, 89 Blazer auto 4 whl drive.
I am thinking that I have trash in the valve body, maybe. It couldn't be bands or plates because there was ablolutely no slipping. Just the all of a sudden outage.
Old Jan 1, 2013 | 12:42 PM
I doubt that the valve body is at fault. It sounds like you have lost the 3-4 clutch pack and the transmission needs to be rebuilt.
Old Jan 1, 2013 | 02:20 PM
atvwarrior's Avatar
atvwarrior will become famous soon enough
Is your speedometer working right ? Mine did this same thing and it was the vehicle speed sensor . Try wiggling the plug around , its on the tailshaft of the transfer case ...........
Old Jan 1, 2013 | 02:41 PM
at around 70 mph it will jump around
as far as the clutch pack wouldn't there have been some slipping to indicate a problem there?
Old Jan 1, 2013 | 02:58 PM
This is an 89 so there are no electronics that have anything to do with the operation of the transmission with the exception of the lockup of the torque converter.
Most of the time what occurs is the TV cable is not adjusted properly and causes low line pressure. The 3-4 clutch pack isn't the best on the early 700R4 anyway and can smoke quite easily. With low line pressure, it is just a ticking time bomb. It likely was slipping a bit before finally going, but it doesn't take much to strip the clutch lining on already worn components.
Old Jan 1, 2013 | 04:05 PM
Also I just confirmed that in 2006 the tranny was rebuilt
GloryImSaved
Jul 17, 2009 09:05 PM
sfesenko
Dec 12, 2008 10:03 AM
