TBI Question
Old Sep 2, 2021 | 07:53 PM
Daltongrant06's Avatar
Daltongrant06 is on a distinguished road
Default TBI Question
I rebuilt the Throttle Body on my sons 1st Gen 89 S10 Blazer 4.3L. After trying to start it, fuel was leaking from where the fitting for the fuel line goes into the TB. Couldn’t find just the gaskets/seals I needed, so bought a whole new TB rebuild kit for 2 gaskets. Put those on and the damn thing still leaks! I’m at a dead end. Came real close to burning it today.
Old Sep 4, 2021 | 09:46 AM
mr.vls's Avatar
The fittings I believe are flare fittings. Remove the fuel line from the TBI and slide the fuel nut back down the line and inspect the flare at the end of the tube and inside the nut and I would also inspect the inside flare of the TBI. if there are any scratches or grooves in the flare connection points that could be the reason for a leak,
Old Sep 5, 2021 | 01:33 AM
mr.vls's Avatar
If the leak is at the TBI adapter and not at the fuel connection make sure that the adapter has the small seal at the tip of the adapter and I believe there is a seal for the body of the adapter to the TBI.
Old Sep 5, 2021 | 01:43 AM
mr.vls's Avatar
https://nemigaparts.com/cat_spares/e...03/gm03-145/Rt
The TBI adapter had a small seal at the tip and and the fuel line has an o-ring at the tube end. It has been a while since I had my TBI apart.
Swimslikearock
14
Sep 18, 2017 04:03 PM
88BlueBeast
Engine & Internal
Oct 12, 2015 09:07 AM
Swaggner
Oct 11, 2011 11:33 AM
C10Fly
Nov 28, 2010 01:11 PM
DetroitMuscle
Headers, Intake, & Exhaust
Sep 20, 2006 08:42 AM
