throttle lag and rev limiter?
Old Apr 2, 2016 | 12:08 AM
Dustin Schaefer's Avatar
Dustin Schaefer is on a distinguished road
Default throttle lag and rev limiter?
Hello, I am new to the blazer world And obviously to this forum so if some of the stuff i say dosnt make sense i am sorry. To start off i recently purchased a 2000 blazer 2 door ls (zr2?) and love every thing about it except two things. First off when you first take off the throttle response seems quite slow, almost like a electronic throttle, and then while accelerating if you really step on it. It just acts like it hits a rev limiter right at 3500 rpm and wont shift or anything until you let off the throttle. So im wondering if that might have something to do with like a bad mass air flow sensor or something along those lines because the current one in it does look a bit crusty. Also i should mention where i got it from the place didn't use it so it sat for a while without being driven. Any help appreciated! Thanks
Old Apr 2, 2016 | 01:03 AM
slimsummers's Avatar
slimsummers is on a distinguished road
First step is to have the PCM scanned and see if it has any codes in it. Autozone will do it and give you a printout for free. If any codes are present, post them here and we'll see what is going on.
Low fuel pressure/flow could be causing the issue, a fuel pressure test would be next on the list of things to check.
And of course the MAF, TPS, and other sensors could be an issue.
Old Apr 2, 2016 | 02:19 AM
Is that a fancy term for see what codes its throwing?
And thank you for the help
Old Apr 2, 2016 | 01:01 PM
Yes, the first step is to see if the Powertrain Control Module has any trouble codes stored. If anything is out of spec and the computer knows about it, a code should be stored. Unfortunately, the PCM is not all-knowing and a sensor reading could be totally wrong but still within the normal range and not throw a code. Or the problem could be something not monitored by the PCM. But that's where you start in the diagnosis process.
hunter4ever12
Mar 17, 2014 01:13 PM
JHSmith5228
15
May 4, 2012 01:28 AM
2000zr24by4
Sep 29, 2009 09:53 AM
blzR
Nov 10, 2007 05:37 AM
2001Blazer4x4
Apr 20, 2005 12:09 AM
