torque converter?
Old Dec 20, 2011 | 12:15 AM
bryan76's Avatar
bryan76 is on a distinguished road
Default torque converter?
i have a 84 k5 the converter went out im wanting to upgrade any suggestions it has 6" lift with 36s a 350/th350 its a DD and a trail truck
Old Dec 20, 2011 | 12:20 AM
chris015's Avatar
gears?
Old Dec 20, 2011 | 12:26 AM
bryan76's Avatar
i think they re 373 havent had the k5 but 2 wks but i will be adding gears if they need it
Old Dec 20, 2011 | 07:23 AM
Unless you have done engine work that would benefit from a higher stall converter, I would stick with the stock stall speed. There are aftermarket converters out there that can provide longer life, but you'll want to get your gears changed to at a minimum 4.10's or you'll find yourself in the same predicament again. 3.73 gears with 36's isn't a good combination for your transmission.
Old Dec 21, 2011 | 08:58 AM
bryan76's Avatar
i have 4.10s just checked i will be adding a cam that is good for stock converters ive read that some people run irocs or vettes converters is that a good choice
Old Dec 21, 2011 | 10:47 AM
Unless you will be altering the RPM at which peak torque occurs drastically, a stock stall converter would still likely be best. Being a lifted truck with large tires, you'll want to select the cam properly so it still maintains its torque at lower RPMs to get the truck moving.
killallblue
Oct 27, 2009 02:14 PM
Shaymus
Aug 1, 2007 07:20 PM
blackhole79
Sep 4, 2006 01:40 AM
Canadian88
Feb 13, 2006 04:04 PM
blazerrick
14
Dec 28, 2005 09:07 PM
