Torque Converter or what?
Old Aug 31, 2012 | 04:46 AM
kendog's Avatar
kendog is on a distinguished road
Default Torque Converter or what?
'04 4x4 Blazer. Having an issue after I drive around town that's fairly difficult to describe. From idle or any lengthy stretch driving at low rpm's, truck will make a loud revving noise at any rpm until I get down the road a ways. Sounds almost identical to a big rig motor. When it does it from say a stop light, I notice I lose power and it hesitates actually getting in gear. No grinding or vibrations, just the big rig sound. Will also make the noise in park once it starts (and sometimes when I start the truck up regardless of engine/transmission temp). Anyone had to deal with this issue before? And how difficult is pulling the tranny?
Old Aug 31, 2012 | 03:10 PM
roypai's Avatar
roypai is on a distinguished road
Check the clutch on your fan first - if its seized up it'll roar pretty loud - should be slight resistance when you move it by hand (engine off/cold) If it's hard or impossible to move by hand OR spins freely I'd start by replacing it first
Old Aug 31, 2012 | 03:49 PM
kendog's Avatar
Thanks man. Guessing the clutch might be holding up the belt and robbing power?
Old Aug 31, 2012 | 10:21 PM
Leeann_Bravada's Avatar
Leeann_Bravada is an unknown quantity at this point
Definitely the fan clutch.
Old Sep 1, 2012 | 04:33 AM
kendog's Avatar
Thanks to both of you. I was finally able to get ahold of my dad, who's been a mechanic going on 30 years now, and that was the first thing he said too. Apparently the clutch has some grips in it that expand and grab the shaft as the oil inside heats up, or something to that effect. Listening to him describe it, you'd think he was talking about his old lady.
Old Oct 29, 2012 | 12:59 PM
kendog's Avatar
*Update*
apparently my truck is having trouble keeping up with the a/c, as the fan will only engage while my compressor is running. flushed and backflushed my radiator. nasty. thermostat is coming open just fine. getting colder outside so not having to use my a/c, but still wondering what the math is up here. a/c condenser maybe?
Old Nov 2, 2012 | 02:47 PM
1sttimejimmyowner's Avatar
1sttimejimmyowner is on a distinguished road
Default Remove the clutch fan and blade.
Installl an electric cooling fan your engine will appreciate it and so will you.More power for the engine.
Old Nov 3, 2012 | 07:16 AM
kendog's Avatar
don't know how to do wiring. if someone had some pictures showing EXACTLY where I run the wires and then explain it, then maybe. have absolutely no experience with electrical.
Old Nov 3, 2012 | 09:27 AM
Talking
Auh its not that difficult and pretty basic to do.Im pretty sure it will show how in the package of your fan if you get a new one.Or you can google search will show.Trust me its nothing thats itimadating its so easy a cave man can do it.LOL
Old Nov 4, 2012 | 04:04 AM
kendog's Avatar
was looking at that. doesn't seem that difficult now that I've seen the diagrams and done a buttload of homework.
killallblue
Oct 27, 2009 02:14 PM
Shaymus
Aug 1, 2007 07:20 PM
blackhole79
Sep 4, 2006 01:40 AM
Canadian88
Feb 13, 2006 04:04 PM
blazerrick
14
Dec 28, 2005 09:07 PM
