Total trans fluid capacity of a 4L60-E?
Old Feb 10, 2020 | 06:12 PM
93S10TahoeLT's Avatar
Default Total trans fluid capacity of a 4L60-E?
Well... if my engine has to come out, then the trans fluid goes with it. So, then, for that.. In the event the removed fluid is not measured.. What is the total fluid capacity for 4L60-E, torque converter included ?
This on a 96 Blazer 4x4, if that matters.
Old Feb 11, 2020 | 12:51 AM
Transman304's Avatar
Here is the service amount and the dry fill amount. These are just estimates as coolers and capacity vary slightly plus you will retain a minimum of 1-2 quarts in torque converter. Why would you lose fluid from engine swap?
Dry fill. 11 quarts
service fill. 5 quarts
Dexron III atf
Old Feb 11, 2020 | 05:29 PM
Now, I may be new to this or it has been awhile but.. Does not the old fluid come out when the engine is separated from the trans?
Old Feb 11, 2020 | 07:49 PM
No, don’t loose fluid in a engine swap.
ken1953
Nov 4, 2018 12:20 PM
comandoed
Dec 26, 2013 07:32 PM
aleking
Feb 19, 2010 08:32 PM
erobe387
Apr 27, 2008 06:12 PM
