Mobil ATF D/M - Automatic Trans Fluid
Old Aug 29, 2013 | 09:26 PM
comandoed's Avatar
comandoed is on a distinguished road
Default Mobil ATF D/M - Automatic Trans Fluid
Am changing trans filter and gasket on my 2000 Blazer 4wd.
I bought 6 quarts of Mobil ATF D/M fluid. Is this appropriate for my truck?
It says recommended for applications requiring GM DEXRON IIIH, Ford Mercon and Allison C-4.
Not recommended for applications requiring GM DEXRON VI.
thanks
Old Aug 29, 2013 | 09:37 PM
KM346's Avatar
KM346 will become famous soon enough
Yep you're good to go. Ive used the Mobil ATF D/M in my trans and t-case... probably not going to need all 6 Qts though.
Old Aug 29, 2013 | 09:57 PM
comandoed's Avatar
yayyyy kool
Old Dec 26, 2013 | 07:44 AM
okiedoak20's Avatar
On the bottles of dextron VI it says it compatible with all lower versions of dextron.
So why is It not recommended for a fluid change....just asking. .
Old Dec 26, 2013 | 07:32 PM
rriddle3's Avatar
Dexron VI is backward compatible, but new transmissions requiring it's properties (full synth being one of them) won't handle the earlier versions. It'll work fine in S10s.
JasonGoneFishing
15
Dec 17, 2014 09:24 PM
ABSLT
Dec 15, 2011 01:16 AM
wienerdog
Nov 4, 2008 04:40 PM
DavidBoone
Jun 21, 2006 06:41 PM
victoryredblazer
Engine & Internal
Mar 25, 2005 04:25 AM
