Trani Lines for flushing
Old Aug 12, 2009 | 02:48 PM
Tony H's Avatar
Tony H is an unknown quantity at this point
Default Trani Lines for flushing
Want to do a simple, pop one line off and refill with New as old gets pumped out. What line is the 'Pump from the trani' ? Does it go to a separate trani cooler then into the radiator.. if not which line to the radiator is the correct one to put a hose into a bucket on?
Old Aug 12, 2009 | 02:54 PM
Ugly_Monkey's Avatar
Ugly_Monkey is an unknown quantity at this point
Search! proly somethin like "flow direction", I know that info is on here cause I was part of the discussion. you may or may not have a external trans cooler.
look on the passenger side of the radiator for TWO metal lines going into the rad, those are your tranny lines. if you have an external trans cooler then there will probably be lines running through the core support and there will be a mini rad infront of the core support.
but I wont feel right if I dont say that if your going to change the fluid you should change the filter aswell!
good luck! hope it helps!
litterbug
Mar 21, 2011 01:44 PM
Tony H
Jun 30, 2009 03:10 PM
Denominator
Jun 5, 2009 07:00 AM
Bad Ramer Jamer
Oct 9, 2008 08:46 PM
fap45
Feb 18, 2008 04:31 PM
