tranmisson fluid and filter change
Old Jul 28, 2007 | 09:18 PM
BigJoeFord's Avatar
BigJoeFord is an unknown quantity at this point
Default tranmisson fluid and filter change
Ok guys i have done this to my 93 s10 blazer 4x4 before. and i would told by gm dealer to use 12 quarts of any atf and that was fine. My question is Does the 91 s10 4x4 take the take the same amount of fluid. thanks in advance
Joe
Old Jul 29, 2007 | 02:13 AM
lennyblazer's Avatar
lennyblazer is on a distinguished road
Default RE: tranmisson fluid and filter change
It should tell you in the owners manual or you can find out in a Haynes or Chiltons manual that you can probably find at the local library if not buying one is a great investment and should be able to find one at a local parts store or online.
-Lenny
Old Jul 29, 2007 | 02:16 AM
BigJoeFord's Avatar
I have the Chiltons manual and i didnt even think to look haha. somtimes u just have to do a little reading to find the answer.
Old Jul 29, 2007 | 08:18 AM
12qts is the dry fill... A pan drop and filter change will probably only swap out around 6 quarts. I usually put about 5 qts back in, then check the level after starting the engine and running it through all of the gears, then putting it back in park.
Old Jul 29, 2007 | 03:21 PM
BigJoeFord's Avatar
Thanks guys it was only 5qts now it's going a little better.
KM346
Nov 23, 2014 04:32 PM
LannyL81
Feb 27, 2012 11:58 AM
darknight
Nov 24, 2011 07:02 PM
boondoggle
Dec 15, 2010 08:36 PM
DaleA
Jan 13, 2009 08:50 PM
