tranny ?
Old Dec 31, 2017 | 05:41 AM
98 4x4's Avatar
98 4x4 is on a distinguished road
Default tranny ?
Hello all I have a 98 4X4 -4 door 4.3. Shifting from park to any selected gear PRND321 is very hard, I disconnected the linkage it is smooth on both ends and the leg on the tranny moves fine, however when all connected it is very hard to move! Any suggestions, Thanks in advance
Old Dec 31, 2017 | 12:03 PM
Sounds like the cable is binding. Have you tried moving the cable while it's disconnected?
Old Dec 31, 2017 | 12:09 PM
98 4x4's Avatar
I have it moves free so does the linkage on the transmission
Old Dec 31, 2017 | 12:14 PM
So, the shifter moves fine, the lever on the transmission moves fine, and the cable moves fine, but you put them together and it binds? I'm stumped.
Old Dec 31, 2017 | 01:27 PM
98 4x4's Avatar
Me as well, it does not make sense
Old Dec 31, 2017 | 02:15 PM
odat's Avatar
Check routing of cable and and any mounting brackets - something may have flipped up off the road and got tweeked causing miss alignment and causing a bind when assembled
Old Dec 31, 2017 | 02:58 PM
oldeerslayer's Avatar
oldeerslayer is an unknown quantity at this point
Column or floor?
Old Dec 31, 2017 | 05:06 PM
98 4x4's Avatar
no on top, and I will look at the cable again thank you
bajablazer93
Feb 28, 2016 04:15 PM
ski.dive
Feb 7, 2014 05:18 AM
