Tranny bolts need help
Old Mar 17, 2011 | 10:40 AM
Shane1891's Avatar
Shane1891 is on a distinguished road
Question Tranny bolts need help
Im doing a tranny. I have everybolt out of the bellhousing except for two. These are kinda in the middle of each side, and the bolt is like in a hole kinda and I cant get a socket in there.anyone know what size it is or what to do
96 v6 auto blazer
Old Mar 17, 2011 | 12:30 PM
atvwarrior's Avatar
atvwarrior will become famous soon enough
Its either a 15 mm or 9/16 and use a long extention .
Old Mar 17, 2011 | 07:13 PM
TZFBird's Avatar
TZFBird is on a distinguished road
9/16 is a better fit but 15mm will work if that's all you have. If you already have the transmission tipped down in the back, that's about all you can do. You need close to 24" of extensions and a universal or wobble at the end.
Old Mar 18, 2011 | 12:42 AM
Shane1891's Avatar
Myn were acually 14mm but I got all of them. The bolts that I need out are like in a hole or something and there smaller. let me find a pic
Old Mar 18, 2011 | 10:38 AM
Shane1891's Avatar
[IMG]
Uploaded with ImageShack.us[/IMG]
This is one I found online thats where thw bolts are. They might even be something eles I dont know
Old Mar 18, 2011 | 10:52 AM
TZFBird's Avatar
Those are alignment studs. You probably cannot get it off because the trans is a bit corroded to them. Just rock the transmission side-to-side or up-and-down and pull. Be careful because it will let loose quickly. Those do not need to be removed, just clean them up a bit before you reinstall.
Old Mar 18, 2011 | 11:16 AM
Shane1891's Avatar
Ok thanks
cory renner
Lifting Tech
Feb 7, 2013 08:50 AM
Melissa Cory Green-Veryser
Jun 7, 2012 09:13 PM
Tinted
Lifting Tech
Jan 16, 2011 12:39 PM
BlazeringSaddles
Oct 7, 2009 12:19 AM
salvy
Oct 30, 2008 03:54 PM
