Tranny flush
Old Feb 2, 2009 | 11:42 PM
bquick0000's Avatar
bquick0000 is an unknown quantity at this point
Default Tranny flush
Im in need of some new tranny fluid. 16500 some miles and still hasent been changed since 50,000. Still running strong with no problems. Its on my tune up list when the weather breaks. Anyways Im droping the tranny pan, changing the filter and adding the 4-5 quarts. I also have read that adding a drain plug wouldent be a bad idea. Is there a good/bad place to add this drain plug? Is there a special plug that needs to be installed? One with a magnet or not? Anybody know who would make a plug that can be added? Im guessing it will need to be drilled and taped. That aint a problem onice I find a plug and location. Any help would be great. Thanks for the help. This forum kicks ***!!!
Old Feb 4, 2009 | 08:44 AM
BlazinMike89's Avatar
BlazinMike89 is an unknown quantity at this point
Default RE: Tranny flush
actually what would be even nicer is to buy a newer pan from online Summitracing.com is very good. they make a deep pan model as well if your intrested, make sure you get the drain plug model
hroofblaze96
Jan 15, 2020 04:39 PM
pfsantos
Sep 23, 2010 03:58 PM
88s10Blazer
Dec 29, 2009 12:52 AM
portcqb
Apr 29, 2008 09:56 AM
ZR 2
Dec 4, 2007 03:53 AM
