Tranny oil change
Old Mar 31, 2011 | 02:01 PM
barkatthemoon's Avatar
barkatthemoon is on a distinguished road
Default Tranny oil change
Hi, just changed the tranny oil on the my 99 4wd on the test drive later we a problem came about,,when i try and pull away the tranny is trying to move off in the last gear used,,,unless i shift the lever into gear 1 then all is well,,,,is this just due to new oil being thick?
Old Mar 31, 2011 | 02:22 PM
So it starts out in a higher gear than 1st?
Did you pull the pan? Could you have disconnected or damaged the wiring inside the pan when you took the pan off or put it back on?
Old Mar 31, 2011 | 02:34 PM
Yeah but all seemed ok,,,it doesnt always do it, im going to get it nice n warm and see if its ok then,
Old Mar 31, 2011 | 02:36 PM
If everything were ok, it wouldn't act that way. The fact that it doesn't always do it makes me think it is the wiring inside even more.
Are you sure you have the transmission full? Checked with the engine running, transmission in park, truck on a flat/level surface?
Old Mar 31, 2011 | 02:57 PM
Yep its full and seems ok when warm,,,will see how it acts tomorow on my commute to work,,
Old Apr 9, 2011 | 08:18 PM
SCrane's Avatar
SCrane is on a distinguished road
When i did a trani flush on my 99, the filter fell out of the hole and caused the trani to act weird. That could be it
Hormisdas
Nov 27, 2012 09:42 PM
chris015
Jun 8, 2012 12:37 PM
the Fllash
Jun 12, 2011 01:19 PM
zippy199
Oct 22, 2009 06:36 PM
lynnmcd
Apr 23, 2008 09:27 PM
